requested vi is not loaded into memory on the server computer
Hi All,
I work on the GPS for myRIO.the example vi was download from NI. Everything is OK when i run the vi on desktop. But when i try to create a remote panel, the problem was occured. I already enable remote panel for myRIO and build a html webpage. Then i build the real time application and run as start up. The html web page was put to this /var/local/natinst/labview/www. When i try to access the web page, the error message was showd "requested vi is not loaded into memory on the server computer". So How to solve this problem?
Many Thanks
Andy
(5,975 Views)
Accepted by wcchung33a
Hey Andy, take a look at the following article and make sure you have the proper options enabled in LabVIEW.
http://digital.ni.com/public.nsf/allkb/506F10CAD6E21EA786256E3100653CDD
Daniel C.
Applications Engineer
(5,954 Views)
Hi Daniel
Thanks for your suggestion. I find out the way to solve it. I modfiy the example GPS vi and add a queue structure. Then i build the application and deploy it. the front panel was show in the html.
(5,945 Views)
