Actor Framework Discussions
Launch UI from State Actor
The state actor template shipping with State Actor launches a UI actor, which launches a nested idle state actor.
What happens if I launch a UI in idle's actor core? Will this launch a UI everytime I switch state from running to idle?
I am asking because I find it sometimes more natural if the model launches its UI.
Actor Framework
(687 Views)
Accepted by Quiztus2
You only ever launch one actor core, regardless of the number of states you have.  When I have used the state pattern actor, that actor core has belonged to the immediate child of State Actor (which I typically refer to as the "context").  That actor core runs exactly once, for the life of the state actor, so you could launch a nested actor from there.
In the example, Process State is the context actor.  It has an actor core, which actually does launch a nested actor - Process Actor.  Idle and Running do not have actor core overrides.  Launching either Idle or Running will start Process State:Actor Core, which will launch Process Actor.
(662 Views)
This was not obvious to me, but it makes complete sense.
Actor Framework
(616 Views)
