Additional NI Software Idea Exchange
Siddharthan
Adding persistance To Alarm specification Page
Status: Already Implemented
This description is indeed delay duration. Please comment if that is not what you are looking for.
Here is a small idea that will be really value added in Alarm Handling
In cases of using sensors like inclinometer, thermocouples, LVDT and etc, there are chances where noise peaks in signal might go Out Of Limits. These kind of peaks are usual in the sensors where it stays not more than 5 msec. So in these case, We can use Persistance to avoid inducing false alarms. We can ignore the noise peaks whose period is not more than the defined time (mscec).If the peak remains more than the specified time, then the alarm should be induced.
The Persistance might be given in msec.The user should also be able to enable/disable this option.
-SID
2 Comments
Carl_Prevas
It sounds like what you are describing is what the Delay Duration does. The documentation for the configuration page is a bit vague:
http://zone.ni.com/reference/en-XX/help/372846C-01/veristand/cp_alarm/
But the VI documentation is more explicit:
http://zone.ni.com/reference/en-XX/help/372846C-01/veristandmerge/vs_set_alarm_data_vi/
- Carl
NAKeel
Status changed to: Already Implemented
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
