Additional NI Software Idea Exchange
iwane
[Drivers/Veristand] More detailed error messages
Status: New
Currently error messages are quite vague - they say what failed, but don't say where. It might be fine in LabVIEW development, where error pops up in the exact location on the block diagram, but it's not well suited for Veristand, where all we have is the error message. Take this as an example:
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -1074384704 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI-XNET:  (Hex 0xBFF630C0) A property value was out of range or incorrect. Solution: specify a correct value.
NI VeriStand:  NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> NI VeriStand Engine.lvlib:Initialize Inline Custom Devices.vi >> Custom Devices Storage.lvlib:Initialize Device (HW Interface).vi
I'm trying since 2 days to figure out which property is invalid - I have 4 CAN channels and 2 LIN channels in the SDF... If there was an information about the channel/value that causes the error, it'd be far easier to sort the problem out.
Piotr F.
Hardware Engineer @ ZF
