Additional NI Software Idea Exchange
MichaelBalzer
Functional Safety Editor file dialog should remember last used path
Status: New
Currently the Functional Safety Editor file dialog always defaults to the path %userprofile%\Documents\LabVIEW Projects\Functional Safety Programs when opening or saving user programs. This is regardless of where the user program was opened from, or where the program was last saved to. This is unlike LabVIEW, where it will always remember the last used directory and use that as the starting path for file saving/loading.
The default file dialog path for the FSE can at least be changed in %localappdata%\National Instruments\Functional Safety State Machine Editor 6.0\Preferences.xml (under the key NationalInstruments.Shell.ApplicationFeatureSetDefaultDialogDirectory) to a more sensible default path (the root of your preferred version control system). Even so, it is still tedious needing to change folder paths to a given project for every save or load operation.
A better UX would be to remember the last used file path, and use that as the starting path for any file open or save dialogs. Much less clicking and navigating required.
(Labelled this as System Configuration API, but the FSE is its own product)
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
