Additional NI Software Idea Exchange
Eric.M
Get FPGA bitfile Version in VeriStand Definition File
Status: New
Hey there,
Versioning is often a fairly important matter when it comes to long/large projects. When a new FPGA bitfile is generated in LabVIEW, there's a possibility to change its version (in the build specification). As a result, a parse of the .lvbitx file as text file can be used to decypher the aforementioned version (it's following the <BuildSpecVersion> tag).
Though, there's no simple way (aside of making a Custom Device or modifying the accepted tags in the xsd file)) to get this information in Veristand after importing a new FPGA personality. The version may be important, but more information about the bitfile might need to be made public in this window :
In fact, there are a bunch of information that are readable in VeriStand about the model imported (name, version...). Once more, the FPGA needs the same feature 😉
Have a great day,
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
1 Comment
MathieuSteiner
Must be done
There is NO way to prove our customers from VeriStand which version has been used to build the lvbitx
