One of my customers wants to scale voltage to scaled data with look-up table, but calculated channel in VeriStand 2011 does not support it. Custome device doing LUT scaling might be created, but it is better to offer LUT scaling function
The lookup table works, but if you want to import a table from file it does not import decimal values. If you import a table from max it is not an issue.
