Whenever I delete a signal (whether it's a custom device, user channel, calculated channel, etc.), VeriStand goes through to delete that signal from anything referencing it. This is often nice but at times undesirable because I may plan to add it back again at a later time with a new custom device with the same signal names, for example. The auto deletion of all references means that I'd need to go back to relink all of the broken references even if the missing signal gets restored later anyway. Some of my channels are used in 20+ places.
I'd like to see VeriStand prompt me or give me an option as to whether I want to delete all references. If I choose not to delete the reference, I understand that an error will show up later if I try to deploy or run. Thanks.
