Often times, the values of numeric indicators are changing rapidly and it is necessary to create Calculated Channels with Averaging [Smoothing] functions to make it easier for the operator to interpret the data. When you need to do this for dozens of channels, this is very time consuming for the end user and requires unnecessary resources of the RT controller in performing these calculations.
With charts, it is possible to edit the Streaming Rate, but with Numeric Indicators this is not possible.
Request:
- Add an option in the Configuration Pane, for the numeric indicator selected, to Average the channel value by xx points (n)
