02-27-2012 09:35 AM - edited 02-27-2012 09:37 AM
I see the option to choose classic or enhanced checksum with the NI USB-8476, but is it possible to specify my own checksum?
I want to look at a response to a frame sent with an incorrect checksum.
Solved! Go to Solution.
02-27-2012 11:11 AM
You cannot specify your own, but if your slave is expecting enhanced, you can send classic (or vice versa) and it will be incorrect.
12-22-2015 01:14 AM
I am using a NI 8476 LIN Interface.
I wonder if it is possible to send a full frame with an inverse checksum. (sum of bytes)
Actually if it is possible to specify you own checksum...
Thank you very much,
Cristian
