CAN Frame Channel Conversion Library - Add New Channel Will Not Convert to Channel
I have hit a roadblock with the CAN Frame Channel Conversion Library v1.0.2.  I don't think that I am using the "Add New Channel" vi properly because it always causes the Frame to Channel to fail.  The Channel to Frame conversion works fine.  I have attached the block diagram and front panel of a simple example.  This VI returns the following error when converting from Frame to Channel:
Error -8702 occurred at Convert Frame to Channel.vi
Possible reason(s):
A call to the library encountered a null pointer.
Ensure that all inputs to the VI have a valid value.
In the case of arrays, ensure that the array isn't empty.
Any help would be appreciated!
CLA, CTA
(7,581 Views)
Accepted by LVB
This issue has been solved by upgrading to the CAN Frame Channel Conversion Library 1.0.3 and placing the frchconvlib.dll file in the C:\Windows\system32 directory.
CLA, CTA
(7,560 Views)
Hello, is there a 64 bits version for the frchconvlib.dll?
(2,601 Views)
The frame channel conversion library hasn't been supported for probably 10 years or so now.  Today NI would recommend using the XNet drivers, and using the conversion session.  I would recommend you use my Signal Frame Conversion API.  It uses the XNet database tools but then uses pure G to convert and scale values.
(2,590 Views)
