Automotive and Embedded Networks
CAN bus messages frame rate
I need to measure CAN messages frame rate in my vi just like in Bus monitor.  It is important to me because some measured devices have problems with CAN communication and I need to put into report with all other measurements.  I am using NI-XNET, NI 9862.
Can anyone attach example of simple vi which will calculate real time frame rate of all incoming CAN messages?
(2,523 Views)
Have you seen the NI-XNET Hardware and Software Manual?
NI-XNET Manual
http://www.ni.com/pdf/manuals/372840l.pdf
Chapter 4 goes over some of the different property nodes that you can use to obtain different data points.
Anson K
Applications Engineering
(2,483 Views)
