07-18-2018 04:02 AM
I need to measure CAN messages frame rate in my vi just like in Bus monitor. It is important to me because some measured devices have problems with CAN communication and I need to put into report with all other measurements. I am using NI-XNET, NI 9862.
Can anyone attach example of simple vi which will calculate real time frame rate of all incoming CAN messages?
07-19-2018 03:54 PM
Have you seen the NI-XNET Hardware and Software Manual?
NI-XNET Manual
http://www.ni.com/pdf/manuals/372840l.pdf
Chapter 4 goes over some of the different property nodes that you can use to obtain different data points.
Anson K
Applications Engineering
