03-10-2017 02:25 PM
Hello. I am learning how to use ADCS for UDS communications.
For hardware I have NI XNET CAN PXI-8313.
All examples for ADCS show how to set up communications, open diagnostics, read and write. But, they do not show if I still need to configure CAN interface, such as termination.
Examples for XNET show how to set up termination.
I am assuming I have to create XNET section in parallel for the same CAN interface so I can set up termination. I did not see termination in properties for diagnostics session.
03-10-2017 02:35 PM
You can create a stream session in parallel with ADCS to set the termination like so:
03-10-2017 02:38 PM
ADCS also has a dedicated property that can be used to set the termination if you do not need to set any other interface properties.
03-10-2017 02:52 PM
Thank you. I missed this settings.
