07-29-2010 12:07 AM
In my project I use a USB CAN converter (NI USB-8473). I have several adapters for different customers. When I connect an other adapter than was connected before, my LabVIEW program only recognizes it when I start MAX.
The adapter receives the same address CAN0 as the previous adapter, but obviously not before MAX is started. This happens when an executable is run (on a computer without LV) or on the LabVIEW development system. I do not have to stop my program.
Why is this? Can I trigger the detection of the converter out of the program?
Greetings,
shb
Solved! Go to Solution.
08-02-2010 09:55 AM - last edited on 12-16-2024 04:39 PM by Content Cleaner
Hi shb,
I have tried to reproduce the issue that you are describing with one USB-8472 and one USB-8473. Using the LabVIEW NI-CAN example <LabVIEW folder>\examples\nican\Frame - Basic.llb\CAN Transmit - event based.vi, I could stop the VI, unplug one USB device, plug in the second and re-start the VI without causing any errors...
May I ask you which NI-CAN driver version you are using? I have used the latest one, NI-CAN 2.7, which is available as a "side installation" from NI-XNET (setup.exe can be directed to only install NI-CAN). You can find the download here:
NI-XNET 1.1 - PharLap, Windows 7 64 bit/7 x86/XP/Server 2008 x64
If upgrading does not resolve this issue, I will try to get hold of a second USB-8473 to exactly reproduce your setup...
Best regards.
Sebastian
08-02-2010 02:48 PM
Hello Sebastian,
I will try NI-CAN 2.7 on Wednesday. Currently I use NI-CAN 2.6.3. I hope to mark your post as solution thereafter. Anyway, thank you verry much.
Greetings,
shb
08-04-2010 09:38 AM - edited 08-04-2010 09:40 AM
Hello Sebastian
This did the trick. Thank you very much. This is the solution plus a kudo at least.
But I have two questions:
- Why is NI CAN 2.7 shown as 2.6.2 when building an installer in LabVIEW? In MAX the version is shown correct.
- Why does CAN 2.7 depend on LabVIEW 8.2.1 Runtime Engine? This does not make sense to me. And I do not have this installer CD here...
Greetings,
shb
08-09-2010 03:31 AM
Hi shb,
the indicated version 2.6.2 of NI-CAN during the creation of an installer/deployment is just a cosmetic issue NI R&D already knows about. It is filed under the reference CAR# 214017 and should be fixed in an upcoming version of NI-CAN.
As for the dependency on the LabVIEW 8.2.1 run-time engine, I can only guess that maybe NI-Spy (which is included with NI-CAN) is programmed in it. If you have downloaded NI-XNET 1.1, you should find the necessary setup msi file in the following directory:
<extraction directory>\Products\LabVIEW_Runtime_Engine_82\lv82rte
Sebastian
