Automotive and Embedded Networks
Impact of Synchronization Jump width setting in CAN network
CAN network is working with 500 kbps,one of the ECU had SJW(Synchronization Jump Width)setting as 2Tq(Time Quanta)whereas other ECU's in network has SJW setting as 3TQ.Will such CAN network work?What is impact on ECU having setting as 2Tq?
(1,710 Views)
HI,
I think it should work.
You can find more information here http://ww1.microchip.com/downloads/en/appnotes/00754.pdf.
To be sure with the answer can you give more details?
bhovhann
(1,645 Views)
