Automotive and Embedded Networks
NI USB-8473
How can I convert this time stamp to real time
3360336873
(7,287 Views)
Hi krasnal,
If you are using LabVIEW, you can simply use the To Time Stamp function under the Timing Palette. Be sure to wire in the input value as a double and it will give you a Time Stamp in terms of Date/Time.
Raj
Applications Engineer
(7,268 Views)
