Automotive and Embedded Networks
The bus monitor doesn't show anything
Start is pressed in the bus monitor, but no signal is received,The controller is connected。
(3,198 Views)
Are you using CAN?
Is the correct baud rate have been set?
Is the termination resistor have been added? If not, you can enable software-selected termination resistor on NI-XNET device in Interfaces and Database > Enable Termination.
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
(3,176 Views)
I am using PXIe-8880,XNET-PXIe-8510,
the correct baud rate have been set,also the termination resistor have been added,But I still don't get any signals.
Here is my setting.
(3,173 Views)
Just to be clear the bus monitor doesn't display signals, it only displays frames.  The selecting of the database is just used to select signals to transmit.  Also it is possible that you have 500k baud but need a custom sample point other than the default one.  I've never seen custom sample points needed for CAN 2.0 except at times when the wiring was not standard.  There should be only two terminating resistors on the bus, one at each end.  And each node should not be more than a few inches from the bus.  CAN is pretty robust and often times it will work even when these restrictions aren't used.
(3,153 Views)
