Biomedical User Group Discussions
3D Image Reconstructor (2013) cannot read DICOM image file
We have encountered a puzzled problem when using 3D Image Reconstructor (version 2013). It does not read the image correctly. All pixel values are -1000. The value was verified using the Read Image Express VI in the Biomedical toolkit (version 2013). However, the DICOM tags seemed read correctly. When we used the 2012 version, the same file was read correctly. Any insight?
Wei Lin
Message 1 of 8
(8,482 Views)
Hi Wei,
Could you please attach a sample DICOM image? So that we can investigate what the problem is.
Message 2 of 8
(4,349 Views)
Hi Bo,
Files attached. There is also another bug in the 2013 version that the file name input is case sensitive. The DICOM files had the extension "DCM" originally but were not recognized ("file not found" was the message) until I changed it to lower case "dcm".
Wei Lin
Message 3 of 8
(4,349 Views)
Hi Wei,
We appreciate your report and share of the data. We will look into this. Will you be urgent to have a fix?
Thanks!
ZJ
Message 4 of 8
(4,349 Views)
It is not very urgent but it would be appreciated if this can be resolved soon as most of our computers have LV 2013 installed. Thanks.
Wei Lin
Message 5 of 8
(4,349 Views)
Hi ZJ,
Any news on the 3D Image Reconstructor issue? Thanks.
Wei Lin
Message 6 of 8
(4,349 Views)
Hi Wei,
We confirmed this is  a bug in 2013 version. We will fix it in next release.
Thanks for your report!
Message 7 of 8
(4,349 Views)
So right now the 3D image resconstructor (2013) has a bug in reading DICOM image file? Then I have to delay my update. By the way, would you please inform us when the bug is fixed? Thanks.
Message 8 of 8
(4,349 Views)
