08-18-2013 11:45 AM
guys i'm waiting . could you please help me ?
08-19-2013 05:38 AM
Hi Hami,
Well the magnitudes of the ECG and EMG signals for the simulated and real examples are completely opposite, so just by swapping the ECG and EEG magnitudes around for the simulated waveform and making the ECG value about x10 the EEG value you will definitely see the R-waves in the EEG+ECG graph.
Trouble is you will get a lot more of the ECG waveform characteristics showing in the combined graph, but at least you will see the R-waves!!
Chris
08-19-2013 06:01 AM
hi chris can you simulate it with labview ?
08-19-2013 10:59 PM
Sorry Hami, but I haven't downloaded the BioMedical Toolkit as yet - I hope to do it some day, but don't hold your breath
08-20-2013 08:19 AM
Take a look at the attached. I believe you wanted to filter the ECG out of the EMG, correct?
08-20-2013 10:31 PM
hi thanks a lot for your attention. your vi work well . I want to filter the EEG out of ECG . please help me thanks again .
08-21-2013 09:52 AM
OK. Here is EEG filtered out of ECG. Please compare the two to see what I had to change. Also, I threw in a filter on the EMG so the "EMG noise" in the ECG would be a little different than the clean EMG data. This makes the simulation a little more realistic.
08-21-2013 11:44 AM
i changed EMG with EEG but i can't get good result .
i can't clean EEG from ECG artifact .
