11-25-2014 06:21 AM
Hi all,
I am trying to Open, read and view the EEG signal stored in .EDF file via Labview.
Do you have any .vi template file for such task?
11-26-2014 03:40 AM
If you have Biomedical Toolkit, check out this - https://decibel.ni.com/content/docs/DOC-23685
11-26-2014 05:52 AM
Hi Thank you for your reply.
I have installed the Biomedical Toolkit, however Read Biosignal Express VI doesnt appear for me to choose. Any idea why that maybe?
12-02-2014 10:48 AM
Hi sorry for posting here as I do not know how to create a new discussion post. I got a question regarding ECG extraction. The biomedical ECG workbrench stuck at 10% I not sure why. I am processing a 12 Mins ecg data. Please help me
12-02-2014 07:57 PM
Could you please send us the data file to have a look?
Thanks!
12-02-2014 10:13 PM
Hi I managed to upload the file. Please find attached file. The csv file is the one I converted using the convertor in biomedical workbench. Both tdms just stuck on the ECG extractor
12-03-2014 12:30 AM
I need help with this too. I followed the labview tutorial for ECG extractor but it didn't extract the ECG that I want. It show nothing being extracted.
12-03-2014 12:39 AM
What's the unit of your data? The input range for your data is not a normal range for ECG (several mVs). Could you please divide by 1000 and try again?
Thanks!
12-03-2014 12:56 AM
The root cause should be the sampling rate. Currently, it is default 1 sample/second. That means, there are several hours long signal for your data. Definitely there is no human heartbeat.
When you convert using File Format Converter, click Advanced... button and set the sampling rate. For example, for your data, I try with 250Hz. Then, use the file as the input in ECG Feature Extractor, it should work.
Here is the result -
12-03-2014 12:58 AM
What do you mean divide by 1000? Sorry. Do you have an example?
