Biomedical User Group Discussions
Write Image (DICOM) express VI
Hi -
I am doing some processing on a stack of DICOM images and am changing some of the attributes.  I need to thus programmatically write the new attributes when I write the new DICOM image stack.  The Write Image Express VI seems to require configuring this information when it is inserted onto the block diagram.  I tried adding inputs/ouptuts on the Express VI once on the block diagram but the attributes input does not seem to appear.  Please advise.
Don
(3,493 Views)
Hi Don,
You are right. In 2012 release, we only provide very few attributes for writing (like dx, dy, slice mm), and they could only be set via configuration dialog.
Thanks!
ZJ Gu
(2,906 Views)
