BreakPoint
Annual bug thread for 2024
Continued from the Year 2023 bug thread.
Happy New Year everyone!
This thread serves as a repository of links to other discussions where newly discovered bugs are discussed.
The rules remain the same:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 10
(1,848 Views)
Zoom + Navigation window tanks performance
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 10
(1,386 Views)
The Zoom + navigation issue now has a Bug#: 2752615
Qestit Systems
Message 3 of 10
(1,314 Views)
Free wires crash LV2024
BUG: LV crashes when autocreating controls/indicators of free wire - NI Community
Qestit Systems
Message 4 of 10
(1,028 Views)
LV 2024 Q1 (don't know which versions are actually affected, but apparently this used to work fine):
If a program calls VIs with invalid invalid file name characters (which are allowed inside an LLB), building an executable throws an error message.
https://forums.ni.com/t5/LabVIEW/Application-builder-Invalid-characters-in-filename/m-p/4386558#M129...
___________________
Try to take over the world!
Message 5 of 10
(1,002 Views)
Value (Signalling) doesn't propagate to child clusters when using nested clusters
https://forums.ni.com/t5/LabVIEW/BUG-Nested-cluster-Value-change-events/td-p/4396160/jump-to/first-u...
Qestit Systems
Message 6 of 10
(910 Views)
Exception that occurred in tdcore_24_3.dll while writing 2D Variant Array:
Labview crashes when writing 2D Variant Array
LabVIEW 2024 Q3 Professional both 32- and 64- bits.
Reproduced on two different OS (Win10/11) on three PCs.
Message 7 of 10
(588 Views)
LabVIEW 2024Q1 and Q3
Bug #: 2923306
https://forums.ni.com/t5/LabVIEW/CallChain-function-extcode-h-is-returning-corrupt-handle/td-p/44063...
External code calling the exported but not officially documented LabVIEW Manager function MgErr CallChain(LStrArrHdl handle) crashes. This worked since at least LabVIEW 5.0 without any problems.
Rolf Kalbermatter
My Blog
Message 8 of 10
(527 Views)
Graphing problem with gigantic values. Discussed here
Message 9 of 10
(492 Views)
Continued here for 2025.
This thread is now closed.
Message 10 of 10
(9 Views)
