BreakPoint
LabVIEW Minutiae (that may bite you someday)
Here are two more classics:
Message Edited by tst on 05.05.2010 06:41 PM
___________________
Try to take over the world!
Message 11 of 131
(17,700 Views)
JackDunaway wrote:
The next bit of minutiae is probably much more well-known to the experienced LabVIEW users, but it is much more common: feeding references through For Loops.
A big exception are Pictures. Programmers might think that a picture wire is just a reference, while in fact is is just a fancy string. All the image function simply append to the end of the current picture if so wired. (This is quite different to the image toolkit).
Here is a classic example:
If we think we do things "in place", by keeping the picture in a shift register, we are completely wrong. "Draw unflattened pixmap" simply appends the the existing picture and you'll run out of memory within a couple dozen iterations. Look at the chart ouput!
(Note that the size of the picture itself remains at 500x500 pixels.)
If we start with an empty picture, the size is constant and manageable.
Message Edited by altenbach on 05-05-2010 09:01 AM
Message 12 of 131
(17,689 Views)
Nice thread idea, JackDunaway
Another one: Empty arrays (>=2D) have "ghost" non-empty dimensions that affects operations with other arrays:
On concatenation, the appended array takes the largest number of columns, which is 10 even if the first aray is empty.
It may be handy when initializing an empty array that must have a minimum column width.
LabVIEW, C'est LabVIEW
Message 13 of 131
(17,647 Views)
The Array to Spreadsheet String looks like a function that plays nicely with others... but maybe not!
Checking out the following bit of code, it appears to produce a clean output. Look at the hex display of that string, however:
18651iD41FB32391C03030
18653iB9F4422D65A20F75
Wow, the "1,2,3" looks just fine in the original output, but what's that "0D0A" doing on the hex display?? You got it, read the Help carefully on that function, and you'll realize this primitive gratuitously adds a platform dependent EOL character to the end of the string.
So, don't make the same mistake I did (see the next post for the corrected solution) in thinking this function is a shortcut to turning a 1D array into a delimited string.
Here's a snippet of the delimiter I use instead:
18655i52A60AA8BE4A669F
(Homework: this VI may be more efficient with an auto-indexed output run into a final Concatenate....)
Message 14 of 131
(17,340 Views)
I am just linking to this "riddle" and bit of minutiae... Tab Control "magically" changing value? (a riddle for all to enjoy). If you want to try to solve the problem, only read the original post. Ben has the solution a few replies down the thread.
Message 15 of 131
(17,336 Views)
I like to use Array to Spreadsheet String because it is simple.  I just remove the last two characters (\r, \n) at the end.
18657i14BF9416EDE85332
- tbob
Inventor of the WORM Global
Message 16 of 131
(17,342 Views)
Note: NOT robust for porting OS's (are you supposed to remove one byte? two bytes?). I have seen a different flavor that actually removes the number of characters returned by the "End Of Line Character" on the string palette, but at this point the code gets dirtier and more obfuscated than the roll-your-own delimiter.
Plus, the roll-your-own version can easily support a Unicode UTF-16 string, whereas the "Array to Spreadsheet String" is stuck in the ASCII realm.
Message 17 of 131
(17,337 Views)
I use the Trim Whitespace on the output.
Message 18 of 131
(17,331 Views)
I just use the Trim Whitespace.vi found in the string pallet to remove the EOL.
GCentral
Message 19 of 131
(17,326 Views)
I never have to port to another OS nor do I ever have to use UNICODE.  So I typically don't think about those things.  But the trim whitespace solution would be the best if you have to worry about those things.
- tbob
Message 20 of 131
(17,309 Views)
