BreakPoint
LabVIEW programming aids
I almost posted it in this thread, but figured it would be more appropriate here.
(For context, I work with several people who abuse stacked sequence structures.  I figured I'd help them out...)
Message 1 of 12
(10,184 Views)
This will be a little less disruptive...
GCentral
Message 2 of 12
(10,181 Views)
I don't know.  Removing a flat sequence might take longer to fix than rewriting the entire program from scratch....
Message 3 of 12
(10,176 Views)
Try crosrulz codeSmiley Wink
There is no code loss! It simply converts the SSS th a FSS then removes the FSS leaving the code within the frames intact.
"Should be" isn't "Is" -Jay
Message 4 of 12
(10,137 Views)
See also this old community nugget 😄 Still valid today!
Message 5 of 12
(10,131 Views)
I love it!!  😄
I'm definitly going to use that.  LOL!
Message 6 of 12
(10,126 Views)
Y'all should use Traverse for GObjects.vi instead of AllObjs[] if you want to nail Stacked Sequences on nested diagrams too.
Or upgrade to LabVIEW 2014 or later, where we removed Stacked Sequences from Quick Drop/palettes altogether. 😉
Message 7 of 12
(10,101 Views)
Sadly, they found the workaround 😞  Place flat, convert to stacked!
Message 8 of 12
(10,085 Views)
Message 9 of 12
(10,075 Views)
You know, I started making a version that does that, and it turns out that TRef Traverse.vi has a Stacked Sequence Structure in it!  Bad Darren!  Granted, it is a single frame just to perform a Class Operator.Remove regardless of an upstream error.  But still.  Maybe NI should change it to a Flat Sequence Structure...
GCentral
Message 10 of 12
(10,065 Views)
