08-01-2015 12:10 AM
Continued from the July 2015 bug thread
The posting rules are as always:
08-06-2015 11:30 PM
CAR #540680, "Key Focus is Lost if a Front Panel Object Begins Blinking"
Because we needed more reasons not to use the Blinking property.
08-27-2015 06:19 PM
Compact RIO ( cRIO )/ LabVIEW Event Handling Bug
If Value Signaled is set, the value changed event is triggered two times. Only happens in cRIO.
Discussed here:
http://forums.ni.com/t5/LabVIEW/Compact-RIO-cRIO-LabVIEW-Event-Handling-Bug/td-p/3184339
08-27-2015 09:39 PM
Before posting something into the bug thread, be sure what you are posting is confirmed, or at least generally agreed upon to be a bug. You posted into this thread only minutes after you posted your original message. Let the original thread have time to be read and a chance for people to try and confirm your bug.
Once you've had a couple people agree you have a bug, or even better, an NI employee agrees and has given it a CAR#, then go ahead and post in this thread.
08-31-2015 10:58 PM
