BreakPoint
Rube Goldberg Code
I had edited my post but you got to it first Smiley Very Happy: I should add, I guess I could have a constant array and index it
@altenbach wrote:
@for(imstuck) wrote:
On FPGA you could make a case structure with a constant in 17 cases, or you could use scale by a power of 2. Good thing it wasn't a 64 bit number....
I'm curious if there's another way to get a 0 as the first element without using the select (and without a build array after the loop). Any takers?
What's the point of your code? Since all inputs are constant, you might as well create a lookup table and use no code at all. (most likely that's what the compiler does anyway ;))
Message 1281 of 2,600
(11,558 Views)
Whats the point of the select anyway? 2^-1 =0.5 rounded away from odd to fit an integer type and...
!1.pngSmiley Very Happy
Fits on a postage stamp
"Should be" isn't "Is" -Jay
Message 1282 of 2,600
(11,546 Views)
found this one here...look into the "cv.vi" file of the llb
Message 1283 of 2,600
(11,531 Views)
Here is code where the programmer is having problems about the "colors" being wrong for the plots when trying to change the visibility.  Actually the labels are wrong because they are rebuilding the array.
Cluster to Array instead of Build Array.  The 13 case case structure to rebuild an array for 0 to 12 items selected.  The Index Arrays inside of that have all of their constants wired.  Overall unnecessary array manipulation.  This could all be cleaned up to this.  But it still doesn't solve the problem.
But knowing what the programmer really wants, all they need to do is set the visibility property of each plot.  And you get this.  Problem Solved.
Message 1284 of 2,600
(11,417 Views)
Is LV 2012 (or was it introduced in 2011?) being used? If so, it could be done with no code and just enabling the visibility checkboxes that are built in.
Message 1285 of 2,600
(11,399 Views)
His VI was saved in LV 2011.  I don't remember which version of LV introduced the checkboxes in the legend.  The visibility property node may not have even existed for individual plots until the checkboxes were introduced.  I don't know.
If the built-in checkboxes exist and they are okay for the programmer, then there is no need for even that final amount of code.  But I went on the assumption that they still wanted a separate means of programmatically changing the visibility.
Message 1286 of 2,600
(11,384 Views)
(seen here)
A case structure with two cases, packed with the same local variables and the same code (except for the presence/absence of a +1 in one place. All terminals just sitting there disconnected. (top left in picture)
A literal translation is shown at the bottom right.
(of course once we figure out what this code is supposed to do, a one-liner the size of a postage stamp might be sufficient :D)
Message 1287 of 2,600
(11,276 Views)
I like bit twiddling when possible, reminds of assembler and stuff where i started, so:
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1288 of 2,600
(11,193 Views)
Hi Y,
like that?
Message 1289 of 2,600
(11,185 Views)
Nice tweak to mine, haven't thought about Logical shift being able to take arrays. 😄
/Y
Qestit Systems
Message 1290 of 2,600
(11,167 Views)
