BreakPoint
Rube Goldberg Code
@BowenM wrote:
I just ran in to this gem while going through someone else's source code...  I actually had to drop probes before I realized what he was doing with all of the multiplication.
Wow! Just ... Wow!
I found something even bigger that after some analysis (and referring to the filename) proved to be a HexString to number. That could be replaced with 2 or three blocks, if memory serves. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1711 of 2,598
(11,951 Views)
The typical Select Function to choose True vs. False,  or False vs. True.
But also timeout event structures that only execute once.  (zero vs. infinite timeout).  And 1 execution while loops that are based on an odd comparison of an inner For loop and its auto-indexed array of iteration values compared to an array of constants.
Seen here
Message 1712 of 2,598
(11,848 Views)
What's the opposite of Rube Goldberg? A post that is reduced to a few unreadable pixels!
(seen here)
Message 1713 of 2,598
(11,828 Views)
(seen here)
1/rube
Bill
CLD
(Mid-Level minion.)
Message 1714 of 2,598
(11,823 Views)
(seen here)
To be fair, it probably was done that way to be nice to the people who skim the thread. It least NI always stores the original size: For example the links to the pictures show:
/t5/image/serverpage/image-id/181928i28E347BD044A009D/image-size/small?v=lz-1&px=200
/t5/image/serverpage/image-id/181929iDD5D2EEB10B9FB79/image-size/small?v=lz-1&px=200
/t5/image/serverpage/image-id/181931i35E41C43A1B8B755/image-size/small?v=lz-1&px=200
You can easily cut the /image-size/ part to the end off and get the full size of each
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 1715 of 2,598
(11,784 Views)
That's really cool, I had no idea that you could do that.
Message 1716 of 2,598
(11,777 Views)
Typically, we can right-click an image...open image in new tab, and then easily zoom there. In this case, the "200" is retained and we need to edit the URL in the new tab to see the full size. That seems to be a browser or forum flaw. You would think that opening an image in a new tab or window should strip the formatting.
At least the forum should turn each picture into a link and show it full size when clicked (like over in the community). I would consider the current behavior a bug.
Message 1717 of 2,598
(11,750 Views)
I happened upon this beauty today.  I think I've seen a similar one in this thread.
Tim Elsey
Certified LabVIEW Architect
Message 1718 of 2,598
(11,391 Views)
(seen here)
Some ways to turn a path into an array of strings. Arguably some are simpler and more universal than others. :D)
Message 1719 of 2,598
(11,265 Views)
With the permission of my intern: What do you do if you write a nice QMH program and then move it to RT, where there are no events? Of course: Generate User Events, every 200 ms or when the RIO gets around to it...
So how do we improve on that? Easy: We replace the data type of the User Event with Array, to make it more scalable.
Or we could get rid of the event structure altogether and queue in the top loop since the process is not time critical at all...
Remember Cunningham's Law
Message 1720 of 2,598
(11,197 Views)
