BreakPoint
What is this and what is it used for
@Henrik_Volkers wrote:
A bit rusty ... and it is not an ancient arrowhead.
I probably could use it "off label" to clean my BBQ; 😄
Message 121 of 294
(4,247 Views)
I am going to let others give it a try. Smiley Wink
I think it can be used in two ways, one where the work is moving and the other where the work is stationary and the tool moves. I am leaning toward the later. In which case...
When I was young and had more time than money, I once built a thing that could be used before using that gizmo. If I had tried to purchase the thing it would have cost hundreds of dollars while the blade the thing used was just a couple of bucks. All I had to do was go at it with a dremel tool.
I should just shut-up now.
Ben
Message 122 of 294
(4,225 Views)
Tool time 🙂
Hint:
Spoiler
All metrics are SI 😄
@I believe I know as well.  There is an obvious sharpened edge on the wider end (whoever has been maintaining that tool should be shot! there is no excuse for the poor blade condition).  The Double dashes on the working end are guides for grinding to desired spec.  @ Ben  The tool is movable but in two controled axis and, the object that it works on rotates on an axis orthaginal to the tools permited degrees of freedom.
Hint:
Spoiler
Googling "Chippendale" might help if, you avoid distractions
"Should be" isn't "Is" -Jay
Message 123 of 294
(4,201 Views)
Jeff, I don't know what you are talking about , g**gle just bring up some funny gauys 😄
No rotation involved, sorry ...  but you are rigth about the edges, they deserve a better handling, and the dashes have other causes
Next hint: windows.
Greetings from Germany
Henrik
LV since v3.1
Message 124 of 294
(4,195 Views)
I think I was headed down the same path a Jeff and may ahve been wrong. My alternative thought it was a molding scrapper used to smooth the wood after using a molding cutter.
While we are pondering what Henrik is challenging us with, I will offer the follow because "Preppers".
Ben
Message 125 of 294
(4,157 Views)
Ben , the R/hr tell everything 🙂 , together with , use that
Henrik
LV since v3.1
Message 126 of 294
(4,209 Views)
So Ben, is that circuit check in "the red zone" so that you can run a proper drill during simulations? Smiley Wink
Spoiler
"Look at high this is! RUN!!!"
___________________
Try to take over the world!
Message 127 of 294
(4,200 Views)
Spoiler
But 'readjust' the knob position, so it will point to X100 😄
Henrik
LV since v3.1
Message 128 of 294
(4,191 Views)
Also see here.
If I found that gizmo in my shop, The above illstrates how I would be mis-using it.
Ben
Message 129 of 294
(4,179 Views)
Ben, no sorry, yours looks more like a woodturning tool.
Solution:
Spoiler
I have a hard time finding the correct translation for a 'Fitscheneisen' .
chisels for making grooves for hinges
It is a wood working tool, still sold
 and you use it to make a rectangular slit into a wood frame to fix a hinge with hidden fixing panels.  ?mortised hinges?
Here is a german video where it is used: https://www.youtube.com/watch?v=3cQaLbYRjD4
(starting at about 7:40)
Henrik
LV since v3.1
Message 130 of 294
(4,175 Views)
