BreakPoint
Why some people say Local Variables are bad...
😉 still made the bad list LOL!!
Let's not encourage bad programming... 😉
LOL!
Message 41 of 396
(14,964 Views)
At least his main program was very streamlined. 😄
Message 42 of 396
(14,962 Views)
ROFL!!!  LOL!! 😄
Message 43 of 396
(14,952 Views)
Ray,
Actually, it would be difficuilt to get the contents of control or indicator to jump the loop boundarys unless you did use a local. eg using a Button to stop several while loops.
On the other hand, it's just a bad example.
RayF
Ray Farmer
Message 44 of 396
(14,929 Views)
Hi RayF,
I used to program that way... using Locals...  And I had some strange behaviors to clean up after the code ... grew...
I now pass info using other methods that are more suitable for scalability..  I know it makes the code bigger at the beginning, but it is more robust.
As a matter of fact, I now implement an architecture that often avoids having two loops..  I prefer that.  The second loop is often not necessary.
RayR
Message 45 of 396
(14,899 Views)
Nothing serious with the following example..  Simple solution was to use a shift register.
from: http://forums.ni.com/ni/board/message?board.id=170&message.id=334278#M334278
Message Edited by JoeLabView on 06-23-2008 07:59 PM
Message 46 of 396
(14,846 Views)
Someone is afraid of wiring directly...  This is probably more a Goldberg.
Actually, why is it needed if the value is almost immediately reset (it the sweep was complete)?   The only thing between setting the sweep complete value and resetting it is writing to a spreadsheet which should be relatively quick..
Maybe a bad example all together of Local abuse...  I just don't see why sweep complete is needed at all..  😮
from: http://forums.ni.com/ni/board/message?board.id=170&thread.id=336680
Message Edited by JoeLabView on 07-01-2008 02:33 PM
Message 47 of 396
(14,760 Views)
We're off to the races...
From:  http://forums.ni.com/ni/board/message?board.id=170&message.id=338085
Message Edited by JoeLabView on 07-07-2008 08:23 AM
Message 48 of 396
(14,678 Views)
The only race condition I see is the error cluster for motor vs the time delay.
Can you spot another?
Ben
Message 49 of 396
(14,669 Views)
I also find the unnamed subvi with one output and no inputs a bit confusing
Message 50 of 396
(14,668 Views)
