BreakPoint
stupid question
In the Array to Cluster primitive why is the default cluster size *9*? What kind of a default value is that?! Who's decision was this? Can anyone ever think of a time where you needed a cluster size of *9*?  Smiley Tongue
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
Message 1 of 9
(8,588 Views)
Well, there has to be a default and "1" is too small and "1M" is too big, so we need something inbetween. What default value would you suggest? 😉
"9" is actually a good default value, because is is somewhat unusual. If the number 9 appears in a post dealing with clusters, we immediately know what the problem is. 😄
Message 2 of 9
(8,586 Views)
As Aristos answered here: "why not?"
Tim Elsey
Certified LabVIEW Architect
Message 3 of 9
(8,584 Views)
And I always thought the preson who was developing the function was listing to this at the time!
-AK2DM
Message 4 of 9
(8,557 Views)
Assuming there is still a valid and necessesary use for this function I disagree that there needs to be a default value. I would really prefer a Coerce to Type function for this, but I think the existing function should break code until a value is set. Add a red X to the icon as a reminder. Is the final value really 9 so often that it is worth the implied shortcut?
Message 5 of 9
(8,547 Views)
Good idea...make the node drop broken until you set a cluster size.  I'd vote for that on the idea exchange.
Message 6 of 9
(8,527 Views)
Idea posted here:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Remove-Default-Behavior-from-Array-To-Cluster/idi-p/17...
Message 7 of 9
(8,485 Views)
42
LabVIEW 2012
Message 8 of 9
(8,473 Views)
As an old hardware guy I assumed it was "eight bit plus parity" for nine bits. Some old mahcines did have byte level parity checking.
Ben
Message 9 of 9
(8,441 Views)
