Chicago LabVIEW User Group
Gummy Bear Vision Challenge
Goal: Use NI Vison to accurately color classify and identify gummy bears. Challenge with gummy bears is their inconsistent shape makes them difficult to use pattern matching.
I stated in my presentation that BMP file format is always preferred.   In this case, I am providing PNG format because the BMP files are over 20 Meg each.  I will post my code solution in about a week but what to see your solutions. BONUS: identify the orientation of gummy bears in degrees.
Create your initial solution using NI Vision Assistant. Use Vision Assistant to auto-generate your LabVIEW base code.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(9,414 Views)
I will post NI Vision Assistant script on Monday.  Looking forward to seeing your solutions over hte weekend.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
(8,306 Views)
NI Vision Assistant script and color classifier files.
https://drive.google.com/file/d/0B2ahen3USkgZOHpNRzF1YWFkQ0U/view?usp=sharing
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
(8,306 Views)
Challenge solution.
https://drive.google.com/file/d/0B2ahen3USkgZR3QybFNrZVZhVU0/view?usp=sharing
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
(8,307 Views)
https://www.kokottautomation.com/assets/GummyBearSolution.zip
Mostly done with vision assistant, labview VI with some colored overlays is interesting.
Jon Kokott
CLA, CLED, CTD, MCP C#
(8,307 Views)
I didn't get around to prevent the double solves, however, its basically is taking the higher score between two "finds" within a certain distance of each other.  Possibly I can get this finished before 3:30
Overlay was wront color on the gren one, its not actually confusing that.
Jon Kokott
(8,307 Views)
