08-20-2014 11:13 AM
I am trying to measure the frequency a 0-14V pulsed output from a turbine flow meter and keep getting the 200284 Error. I am using the cDAQ 9178 chasis and a 9401 digital card and taking the signal in through the bnc connections on the chasis. I have tried the low freqency, high freqency and large frequency range options. I have also tried several different sample sizes from 1 up to 10M with no luck.
08-21-2014 11:41 AM
cwells,
That error is associated with receiving a timeout error before samples are received. Have you taken a look at this article?
http://digital.ni.com/public.nsf/allkb/FEF778AD990D5BD886256DD700770103
I would trying performing some of the steps provided in this document and see if that will remove the error.
