06-14-2022 09:41 AM
I would like to know which counter corresponds to which PFI in NI 9401
I have looked and have not find it in the 9401 data sheet.
Thansk!
Gil,.
Solved! Go to Solution.
06-22-2022 07:34 AM
Each line of the 9401 can function as a PFI line, PFI0 is DIO0, PFI1 is DIO1...
when you configure your counter task, use a DAQmx Channel property node to
tell the task which PFI line to use as an input to the counter.
06-22-2022 11:08 AM
OK
Thanks!
