11-12-2013 03:15 PM
I am new to labview. I have made a vi to record data after every 00:00:10 sec. However, my vi is recording data after every 00:00:10.9 sec. My vi is using the time from my desktop. Is there any way that I can make my vi to take reading after every 00:00:10 sec in place of after every 00:00:10.9 sec? I have attached my vi with this post. Kindly help me.
best wishes
Solved! Go to Solution.
11-12-2013 06:47 PM
Change your DAQ Assistant to Continuous Sampling. That way it will continuously sample. With the finite samples, it just reads when you tell it to.
11-13-2013 01:35 PM
Many thanks for taking time to answer my query. As suggested, I changed the DAQ assistant to continuous sampling and it has solved my problem.
Regards!
