Counter/Timer
How to change the data time stamp from hh:mm:ss:ms to hh:mm:ss?
I am new to labview. I have made a vi to record data after every 00:00:10 sec. However, my vi is recording data after every 00:00:10.9 sec. My vi is using the time from my desktop. Is there any way that I can make my vi to take reading after every 00:00:10 sec in place of after every 00:00:10.9 sec? I have attached my vi with this post. Kindly help me.
best wishes
(6,029 Views)
Accepted by topic author ramanlvm
Change your DAQ Assistant to Continuous Sampling.  That way it will continuously sample.  With the finite samples, it just reads when you tell it to.
GCentral
(6,021 Views)
Many thanks for taking time to answer my query. As suggested, I changed the DAQ assistant to continuous sampling and it has solved my problem.
Regards!
(6,007 Views)
