06-13-2014 01:01 PM
I am trying to measure two signal by using two counters of different NI USB-6501 device. The problem is that they measure one after another so I loose half of the time. Can anyone please help me so that I can simultaneously measure them. I have attached the sub vi which I used in the main vi to control both USB-6501.
Thank you
Somnath
06-13-2014 01:14 PM
Make that subVI reentrant. Then you can have multiple calls of it that will run simultaneously.
