Hi
I have a problem in generating a retriggerable delayed pulse with a single counter(triggered through a signal at gate) using PXI 6070E card. VI was developed in NI LabVIEW traditional DAQ Ver.7.1. I have used the "delayed pulse generator config" VI and a "Start counter" & "Stop counter" VIs for the purpose. But there is no output seen at the out terminal of counter. So I introduced a "wait" VI and set it to 1 sec. Now the pulse output appears but some pulses are missing mometarily after every 1 sec interval. (any solution for this)
I have gone through a few similar requests in the forum but they suggest either to use two counters or to generate a finite pulse train which does'nt fit my application. Moreover PXI 6070E has only 2 counter timers. I am already using one counter to measure the frequency of a pulse train(signal 1). The application requires to generate a delayed retriggerable pulse for every pulse in signal 1. So I have only one counter left.
Can I measure the frequency of signal 1 by analog means.? so that I can use two counters for pulse generation. (Signal 1 is a TTL signal).
Request some help.
Thanks in Advance
Regards
Kalyan
