Hello there!
Though this was long time ago already I need confirmation on the same kind of calculations.
(However, in my case, I am measuring frequency, not reading, also with the 6608)
I thought the stability of 6608 OCXO was 75ppb per year (or 45ppb as stated in the OCXO notes). So therefore 11.25ppb/day. Not 0.45ppb/day.
In any case, if the stability of the OCXO is 75ppb :
- Stability on the 10Mhz clock: 10,000,000*75/1,000,000,000 = 0.75Hz
The question is, if you measure a 10Hz signal with this device, will you have a 0.75Hz accuracy? Or would you have the accuracy of the clock that you use to MEASURE (using a 100Khz timebase):
- Stability on time base: 100,000*75/100,000,0000 = 0.0075Hz
So apart from my measurement error (according to
http://zone.ni.com/devzone/cda/tut/p/id/3619) I have to add up this error like this:
TOTAL ERROR = MEASUREMENT ERROR + CLOCK ERROR = X + 0.0075hZ
Being XX the calculated error made by the frequency estimation algorithm.
