Counter/Timer
Programatically How to generate the Pulse output
Hey Friends,,
I want to generate the Pulse using one digital out channel . I want to switch on and off for every 10ms for 5000 times.
can any one explain me with 1 example program .....
(5,071 Views)
hi
please specify the device that you are using to generate the pulse ouput using digital output. Because not all devices support correlated digital I/O.
but you can do this very easily if you use counter output instead of digital output in any device. I've attached the example code.
thanks
Ravi.
(5,059 Views)
Hii Ravi Actually i am having limited counter o/p module ... ya i know how to use the Counter module..
Actually i want to drive a stepper motor through a single digital output by switching on and off continously for every 10 ms on and off... for about 5000 pulse... so inorder to use a digital signal how can i access it... can u suggest an idea for that.......
Regards
karthik..
(5,041 Views)
Hi
Check out this code. I'm using software timing to control the on time and off time 🙂 and the counter will check if you have exceeded 5000ms. The code will stop after that time.
This will generate a PWM. But I'm skeptical if it will run the motor.
That is because the current output of the Digital Output is very less (mA). If you have a motor drive then it is not a problem.
regards
Ravi.
(5,038 Views)
