11-21-2013 11:50 AM
I have a PXI-6251 card. To trigger simultaneous analog and digital output, I use one of the counters. Since I use all digital lines, I would like to not have the counter output on any of the lines.
Is there a way to remove the counter output from PXI12?
Jonas
11-22-2013 09:55 AM
Jonas,
I am not sure what you mean by 'remove'. You can internally re route counter signals, I have attached a link to explain. If thats not what you meant please clarify what you mean andI will be happy to assist you further.
http://digital.ni.com/public.nsf/allkb/8A85E97855EDADC98625730C00065F58
11-22-2013 10:10 AM
Thanks, I saw that. I was just wondering whether instead of rerouting I can remove a signal from physical pins completely.
11-22-2013 11:48 AM - edited 11-22-2013 11:48 AM
This should work:
Best Regards,
11-25-2013 01:04 PM
Hi John,
Thanks for your suggestion. It seems to work – sometimes.
Since I did not have the time to investigate why it doesn't work all the time, I just repurposed another DIO card for my digital needs, so I don't have to free up this line.
Thanks again.
Jonas
11-25-2013 02:00 PM
If you're not explicitly enforcing the start order of your tasks (e.g. through error chaining) then this might explain the inconsistent results.
Best Regards,
