Counter/Timer
Remove counter output route
I have a PXI-6251 card. To trigger simultaneous analog and digital output, I use one of the counters. Since I use all digital lines, I would like to not have the counter output on any of the lines.
Is there a way to remove the counter output from PXI12?
Jonas
Jonas Zimmermann, PhD
Neuroscience Department
Brown University
(6,131 Views)
Jonas,
I am not sure what you mean by 'remove'. You can internally re route counter signals, I have attached a link to explain. If thats not what you meant please clarify what you mean andI will be happy to assist you further.
http://digital.ni.com/public.nsf/allkb/8A85E97855EDADC98625730C00065F58
Applications/Systems/Test
National Instruments | AWR Group
(6,116 Views)
Thanks, I saw that. I was just wondering whether instead of rerouting I can remove a signal from physical pins completely.
Brown University
(6,113 Views)
This should work:
Best Regards,
John Passiak
(6,108 Views)
Hi John,
Thanks for your suggestion. It seems to work – sometimes.
Since I did not have the time to investigate why it doesn't work all the time, I just repurposed another DIO card for my digital needs, so I don't have to free up this line.
Thanks again.
Jonas
Brown University
(6,077 Views)
If you're not explicitly enforcing the start order of your tasks (e.g. through error chaining) then this might explain the inconsistent results.
Best Regards,
John Passiak
(6,072 Views)
