05-15-2008 07:57 AM
Hi Miaa,
I think the counter looks at the time between the rising or falling edges (depending on settings) and uses an internal 20Mhz clock to calculate frequency.
The 6210 has 2 counters. You could use some external circuitry to multiplex the 10 signals to the 2 counter inputs and program the digital I/O outputs of the 6210 to select between the 10 signals. After the 10 signals have been sampled they could then be displayed on a chart.
This method might be slow maybe 1 second or so (not sure on this) to select and measure the 10 signals I don’t know how fast (or often) you need to sample the frequencies and display them.
This would take some external circuitry.
Stewy
05-15-2008 11:02 AM
Sure thanks for the recommendation on using external circuit. I was reading in the attached chapter 9 about the counters and have still not found how you calculated the values in ring constant for edge and measurement method ?
Can you kindly tell me how these values were calculated ?
PS: Attached is also the manual which describes about counters in chapter 9
05-15-2008 11:53 AM
Hi Miaa,
I am not sure what those settings are. I have never seen those. I am running
When I start a project I usually find an example and modify that or use the DAQ assistant.
I am sure someone on here who is more knowledgeable than I can answer that.
Stewy
05-12-2015 05:51 AM
Hi..
Here my aim to measure the motor speed in RPM using optical proxmity sensor..here im using Ni-USB 6009.Please help me how to measure it.
Thanks in advance.
05-12-2015 06:07 AM
