Counter/Timer
USB 6210 Measure frequency at a specific sample rate.
Hi Miaa,
I think the counter looks at the time between the rising or falling edges (depending on settings) and uses an internal 20Mhz clock to calculate frequency.
The 6210 has 2 counters. You could use some external circuitry to multiplex the 10 signals to the 2 counter inputs and program the digital I/O outputs of the 6210 to select between the 10 signals. After the 10 signals have been sampled they could then be displayed on a chart.
This method might be slow maybe 1 second or so (not sure on this) to select and measure the 10 signals I don’t know how fast (or often) you need to sample the frequencies and display them.
This would take some external circuitry.
Stewy
Message 11 of 15
(2,631 Views)
Sure thanks for the recommendation on using external circuit. I was reading in the attached chapter 9 about the counters and have still not found how you calculated the values in ring constant for edge and measurement method ?
Can you kindly tell me how these values were calculated ?
PS: Attached is also the manual which describes about counters in chapter 9
Message 12 of 15
(2,628 Views)
Hi Miaa,
I am not sure what those settings are. I have never seen those. I am running LV 8.2.
When I start a project I usually find an example and modify that or use the DAQ assistant.
I am sure someone on here who is more knowledgeable than I can answer that.
Stewy
Message 13 of 15
(2,620 Views)
Hi..
Here my aim to measure the motor speed in RPM using optical proxmity sensor..here im using Ni-USB 6009.Please help me how to measure it.
Thanks in advance.
Message 14 of 15
(1,682 Views)
Hi saitej,
please stick with your own thread!
Message 15 of 15
(1,679 Views)
