11-14-2012 06:59 AM
I often see the word "Instance" in NI documentation, but, I don't have a clear understanding of what it means. Can someone please offer a good definition of the word "Instance" as it pertains to Labview? Here is an example of some documentation that would be more useful to me if I understood the intended meaning of the word "Instance"
"The instances of this polymorphic VI correspond to the I/O type of the channel, such as analog input, digital output, or counter output; the measurement or generation to perform, such as temperature measurement, voltage generation, or event counting; and in some cases, the sensor to use, such as a thermocouple or RTD for temperature measurements."
Does it just mean the occasion of usage? or application?
Dave
11-14-2012 07:14 AM
When dealing with polymorphics, the "instance" is the exact VI in the polymorphic that is being called. As an example, I have a polymorphic VI "A". The polymorphic has two instances, "Foo" and "Bar". To bring in your example a little closer, when you wire up a string to the input of A, Foo is actually called. If you wire up a double, Bar is called. So when I wire up a string to A, the instance that is called is Foo.
Does this make any sense at all?
11-14-2012 09:26 AM
No, sorry, not really. What does "instance" mean? In general, not just related to polymorphics.... It is widely used in the literature on NI.com for many different definitions. Can you give a specific definition of the word "instance"?
Does "instance" mean VI in general?
11-14-2012 09:40 AM
from the dictionary:a case or occurence of anything
I wouldn't necessarily say it generally means a VI. More like an occurence of a VI. It gets hard to explain the word without context here. I say this because when you get into reentrant VIs, an instance is a particular clone of the VI that is in memory.
