06-10-2010 08:46 AM - edited 06-10-2010 08:49 AM
I've been tasked with creating a test device capable of outputting three different (and configurable via front panel 0-50Hz TTL) pulse trains. I have a USB-6501 but it does not have any pulse output capable counters or analog outputs. Consequently I've been trying to achieve my goal in software. I have been able to create multiple pulse outputs, but there are very inaccurate.
My real question: which DAQ board can I use to do this? Do I need three counters? Or do I simply need more analog outputs? I could just be sending a square wave to an analog output, right?
06-10-2010 12:38 PM - last edited on 02-05-2024 03:08 PM by migration-bot
Hi OCE,
The counters will be able to hit a higher resolution of frequencies since they can use a faster timebase than the sample clock for a DO or AO task. If you had a board with HW-timed DO (or AO) you could still get good results--the programming wouldn't be quite as strightforward as you would have to build the waveform in software. You might want to double-check AO settling time requirements if you go with AO.
Having said this, the hardware recommendation is going to depend on what form-factor you require:
PCIe: 63xx: All of these boards have 4 counters that utilize a 100 MHz timebase. The boards also support clocked Digital Outputs. The first board in the X Series line is the 6320.
PCI: 6601: Has 4 counters that utilize a 20 MHz timebase. Does not have any analog or clocked digital lines.
62xx: Only has 2 counters. However, these boards support clocked Digital Outputs at up to 1 MHz on 622x and 10 MHz on 625x.
USB: 62xx: Same as above--however, be aware that the 621x bus-powered devices do not support clocked digital outputs. They do have 2 Counter Outputs and some (like the 6211) have 2 clocked analog outputs. The 10 MHz update rate on DO isn't achievable on the USB 625x due to USB bandwidth limitations, but you may regenerate from the on-board FIFO at this rate.
Best Regards,
John
