Yes, but independet of the change-pin capability. For example, if I have a TTL pulses signal and I want to measure the distance between pulses with a counter, Do I have to connect this signal to the Ctr_GATE or to the Ctr_SOURCE?
As I understood, I have to connect it to the Ctr_GATE, and the Ctr will use its own 80Mhz (I am using a PXI 6251) Source signal to count the source pulses between the GATE pulses. That is what I understood, but now I don´t see why you tell me that I should connect the pulses to the Ctr_SOURCE.
It seems to me that I didn´t understood right, or maybe I didn´t explain myself so clear and you misunderstood my question.
I hope that now you can understand better my question and what I want to do, and that you can still help me
😉Best regards,
CJMV
