Counter/Timer
error 1003 when arming 6602 counter for retriggerable pulse generation
I'm trying to configure a 6602 card to count ticks from the timebase, and then deposit a reading to an array when triggered by an external input.
To do this, I've set up counter 1 to be a re-triggerable pulse generator; the pulse from this counter will act as the trigger to take a reading from the main counter.
The problem I'm having is that the counter won't arm, it gives 'error 10003'. I have compressed the problem to a smaller VI, attatched. Any help at all would be much appreciated.
Note - I am using LabView version 6.0
Dan
(6,076 Views)
Hi Dan,
What version of the NI-DAQ driver are you using? Have you tries updating to the latest version of the driver? The latest version of the driver that is compatible with LabVIEW 6 is NI-DAQ 7.1 as is shown in this link.
Best Regards,
Christian Hartshorne
NIUK
(6,033 Views)
Currently I'm using 6.8, I'll try updating now and report back.
Dan
(6,022 Views)
I tried to upgrade the drivers, but the version of windows is too old (needs service pack 6 or later).
I'm not in a position to modify the PC very much, if possible I need to avoid changing it at all.
Is it possible that the drivers aren't the issue, that theres something wrong with my code?
Thanks again,
Dan
(6,017 Views)
Problem resolved Smiley Tongue
(5,999 Views)
