09-25-2012 03:32 AM
I am new to NI labview, in my application, i need to change default signal connection of Ctr0. its output is PFI3, how to change to PFI4?
thanks a lot
BTW, how to post figures here?
10-02-2012 02:21 PM - edited 10-02-2012 02:22 PM
Hi hitbuyi,
You would need to set the following channel property (before starting your task) to choose the output terminal:
If you're using one of the other APIs (e.g. .NET or C) they have similar properties which you may set.
By "figures" do you mean images? If so, you can do it by pressing the Insert/edit image button at the top of the reply window:
Best Regards,
