Counter/Timer
lowpass filter 9401
i use a NI9401 to count a frequency of a signal
in the signal analysis i detect noise
i'de like to apply a lowpass filter (20hz) no my signal
(1,169 Views)
You *probably* only need the 2 properties DigFltrEnable and DigFltrMinPulseWidth.  You'll need to read the manual for your cDAQ chassis because the appropriate pulse width setting will depend on what matters more:  rejecting every frequency below 20 Hz or passing every frequency above 20 Hz.
As I recall, there's generally a factor of 2 between what's certain to pass and what's certain to be rejected.  This arises due to the inevitable quantization that comes with discrete time operations.
-Kevin P
ALERT! LabVIEW's subscription-only policy coming to an end (finally!). Permanent license pricing remains WIP. Tread carefully.
(1,152 Views)
